placham »
https://forums.nicoclub.com/placham-u38577.html
Thu Jun 19, 2008 3:45 pm
Wouldn't OBDII have a second O2 sensor on downstream after cat. And wouldn't it have a flywheel/flexplate position sensor aka(crankshaft position sensor CPS) I think. Also would have that (GST) Generic Scan Tool hook-up port(on passanger side of harness).
I'm just mentioning these because I also have a '95 KA24DE and those are the items that I have on mine. And I believe that I have an OBDII, correct me if I'm wrong.
GST connector, would be near the ECM in the interior part of the harness, if you still have that.
Didn't he mention that he has the motor out of the car, or something?????
Also CPS would be on top of the trans bell-housing right behind the cylinder head, with little metal shield and on 10mm bolt IORC. If that is OBDII specific????
Didn't OBDI and OBDII have a single wire O2 in exhaust manifold, and OBDII had second on down stream, with like 3 or 4 wires (maybe even heated O2 sensor). Don't want to go to garage and check, feel too lazy and tired.
