Hey Guys,
Just want to let you know that I did search, and find some Timing Tutorials on this site. The reason I'm here is because I feel that I have followed them fairly close if not exact and still having issues.
How my timing got off; I was working on the removing guides from my timing chain, when i put everything back together, my car did not start, I noticed i did not have the electric plugs plugged into the dis. so I plugged that in and the car still did not start. Going back on the tutorial, I missed a step and it was the step that you had to take of the dis. cap and make the marking on TDC. =(.
I went to the 240sx manual and read some more on the net. With the dis. in my hands i removed the cap, then aligned it according to this;
Once I was able to do that, and put everything back together, my car started. YAY, right? Wrong, because then it started, did not hold idle, and died =(.
Here is what it looks like when i set my crank at TDC. (excuse the small images, they are from camera phone)
I do not have a timing light either.
I'm really unsure of what to do, and I can not tell if I flooded my cylinders, as I read this can be an issue as well.
