1995 240sx Horn Won’t Stop Blowing
Creolex
Car: 1995 240sx
My horn started blowing non-stop while driving. I checked the fuse and the fuse was fine. To stop it, I pulled the relay switch. Believing that the relay switch was the problem, I replaced it and it started to blow uncontrollably again. Please advise.
centralcoaster33
Car: 1997 Nissan 240SX #5
The switch inside the steering wheel may have gotten stuck or shorted. You might want to take that area apart and check the wires. It's kind of a pita with that rotating switch thing for the turn signals, but it can be figured out. You can test the relay signal line with a voltmeter to see if it's getting power to it. That would help point towards the switch or a short. You could work your way up the wires.
PapaSmurf2k3
Site Admin
^Yup, I was thinking the switches in the steering wheel itself.
