240sx man »
https://forums.nicoclub.com/240sx-man-u13221.html
Tue Nov 15, 2005 2:14 am
My 1995 240 has 46,000 miles on a new engine it is an automatic, runs PERFECT."I THOUGHT", here in Texas we have to run the roller dyno at 2 speeds, the engine uses burns no oil, gets excellent mileage, but failed the NOx, it was almost double, there is a code in it, and it states the 3 way catalyst is bad, but there are 2 cats, i am assuming the front is bad since the O2 sensors are before and after the front converter, here is what the car did, HC(ppm) standard132 current 104 pass (high speed)HC (ppm) standard 136 current101 pass (low speed)co% standard .73 current .42 pass (high speed)co% standard .76 current .43 pass (low speed)O2 1.1 (highspeed)O2 1.2 (low speed)
NOx standard 945 current 2118 FAIL (high speed)
NOX standard 1045 current 2181 FAIL (low speed) I know the converter is probably bad , but the HC wasnt that bad, also i pushed up on the egr valve and the engine stumbled at idle, like the passages were clear, when you rev it up in neutrall, it raises up but drops back down, it doesnt stay up all the time it is reved, I put vacuum, on it and it holds the valve up all the way untill let go, please let me know what you think I should do, ...........("front CAT????") thank you in advance for any help Is this vehicle obd-2?, it has the connector and the 2- o2 sensors, but they classify it as not here in Texas, 1996 and newer doesnt have to go on the roller!!!!
Modified by 240sx man at 2:35 PM 11/15/2005
