1995 240sx engine swap but with automatic??
arman_6872
Car: 1995 Nissan 240sx
I'm considering swapping my stock motor to a sr20det w/turbo, only thing is that mine is an automatic and don't really want to do the whole auto to manual conversion, kinda like the ease of not having to clutch anymore. What would I need to do this conversion?
AZ89two4Tsx
You will not enjoy an automatic.
Do the manual conversion.
whyteboi
Car: 1993 Nissan 240sx
give me the 5 speed transmission so i can swap out my slush box and you can keep yours......
really tho, the money it takes to have an auto last isnt worth it imo
s13 iDRIFT
Car: White s13 Hatch
so you basically want a auto?
WHY!!!!
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
AZ89two4Tsx wrote:You will not enjoy an automatic.
how do you know?
Personally i enjoy automatic's too.
whyteboi wrote:really tho, the money it takes to have an auto last isnt worth it imo
Really? Cause the stock 5spd SR trans is so tough what that breaks with a little more then 300whp? between 3 friends they have gone through 6-8 sr' transmissions.
s13 iDRIFT wrote:so you basically want a auto?
WHY!!!!
WHY!!!! The hell not?people still run rota's/sportmax's i'd rather see him run a auto and nicer wheels, f*** it's his car, let him do what he wants.
from what i remeber a few years ago there was a guy with a S13 coupe with a SR/Auto that got a f***ing MINT for that car when he went to sell it. why not do it? it won't feel as fast but not loosing boost between gear changes makes it all worth it.
s13 iDRIFT
i mean i can see why because he keeps boost, and all. i have a friend that wants to boost his auto civic, i see why.
but i still think why would anyone wanna swap to a auto, i mean i think a 5 speed is hella fun, but thats me, his car, do what he wants, im not saying no dont swap to auto! but good luck OP!
SR24DET
Car: RMS13
arman_6872 wrote:I'm considering swapping my stock motor to a sr20det w/turbo, only thing is that mine is an automatic and don't really want to do the whole auto to manual conversion, kinda like the ease of not having to clutch anymore. What would I need to do this conversion?
It wouldnt be all that different from a manual SR swap. You need the engine, auto transmission, ecu, ext.... the same stuff you need to do a manual SR except auto parts. The you can use your auto KA drive shaft. You will need a SR radiator. The problem is you will need to find an auto SR radiator. That might be a little tricky to find. If not, you could use a manual one and fab something up for your transmission. The wireing would also be a little different. Im sure most would be the same. The rest would be simple. Buy it. Drops right in on stock KA motor mounts. Just read about Manual SR swaps and change things a bit to accomodate the auto transmission.
Flicktitty
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
i personally don't think it would be as hard as your making it out to be. Call up any GOOD engine importer and ask if they have one or can get a auto SR. (i called a few about getting a auto Ca18det for a daily) and they are actually pretty cheap for a swap (motor,trans,harness,etc) just run a aftermarket SR radiator and then get a aftermarket transmission cooler (a good one) and a trans temp gauge and go have some fun!
SR24DET
Car: RMS13
I didnt think I made it sound too hard. But you are right on the money
