obos »
https://forums.nicoclub.com/obos-u22769.html
Mon Apr 24, 2006 11:33 am
The car was bought with a bad lower ball joint on the front driver side wheel. I henced replaced it, and found that the bushing in the tension rod was also torn. Replaced that too. I also replaced the all the stock shocks and springs with AGX adjustables and TEIN S type springs. With every repair/upgrade, the car got smoother and smoother. However it still shakes violently at 70mph, and sometimes it does't shake at all. I've tried swapping wheels around to see if it was the wheel, but the shaking is still comes from the front driver side wheel. I've also noticed recently, there is excessive wear on the inside of that wheel.
Do I need an alignment, which is my next step anyways, or is there something else I should also check?
Thanks much
