surfwax95 »
https://forums.nicoclub.com/surfwax95-u19092.html
Fri May 06, 2005 8:52 pm
I just took a job delivering pizzas (saving for turbo) which means a lot of city driving (50 miles in 4 hours), it's pretty much non-stop clutching action shifting 1st to 2nd back down to 1st.95 240sx, 122,000 miles, 5spd, stock drivetrain.
When pushing in the clutch pedal it feels as if it's letting down in stages...i.e. if the floor were 100% down, the clutch sticks a little at 50%, 75%, 95% accompanied with a little *click* each time i pass the catch point. This annoyance doesn't affect how the car drives, but I have noticed that in neutral (clutch engaged) there is a whining noise coming from underneath the car, but as i push in the clutch, the noise goes away. What do you think could be the reason for the sticking and noises in the clutch/clutchpedal?? I've checked all the lines for leaks and the master cylinder. They both seem fine.The clutch probably has around 25,000 miles on it. Any help is appreciated.
