1995 240SX : camber on right rear wheel is too positive
unichi
The right rear wheel is way too positive, like 1.5 degrees on the positive side. I was wondering if there is a common problem with the early S14 that i can fix myself. I lifted the car and was measuring the different parts, but they all seemed to be similar. Can I install a shim between the hub and the axle housing? Any advice is great. Thanks!
todd
JeromeS13
Car: 2008 Subaru Impreza STI
Shim? Sure, if it were FWD. If they can't adjust it down any, it would appear something is bent.
180fan
Car: 89 fastback
whoa, +1.5 is way high.
When was the last time you went and got an alignment done?
unichi
Actually, it was at +1.5 right after my last alignment. I'm thinking at this point I need to take it back and have them do another alignment and figure out what is wrong with the car. I can't figure it out.
JeromeS13
unichi wrote:Actually, it was at +1.5 right after my last alignment. I'm thinking at this point I need to take it back and have them do another alignment and figure out what is wrong with the car. I can't figure it out.
Chances are, like I said before, something is bent. Or they don't know how to do adjust the camber on a 240sx. (Even though, if its a newer computerized machine, it shows them pictures)
