Harrythook »
https://forums.nicoclub.com/harrythook-u249617.html
Wed Oct 14, 2015 5:31 pm
I just noticed this thread. Need to put my 2 cents in.
On a KA-T motor at cruise you are more than likely still into boost. As a rule we dont want to see anything below 14.7, I try for around 14 flat. On decel or fuel cutoff its fine to see 17 or so. Lean is mean under boost, at any level. Any change in fuel delivery or boost levels can drastically change your air/fuel ratio in a bad way.
I would talk to a tuner. I use Nistune here, and do my own. If you get it right, that KA-T is a lot of fun on the street. And with the setup we have, I can go from 8PSI to 18PSI in a half hour, but that tends to break things.
I gotta update my build thread.......
