1995 240 SX SE Starter wont turnover
klaybus
Car: 95 Nissan 240 SX SE
I have an intermittant start problem with my 240. Sometimes it starts & other times it won't turnover. The battery is 6 mos. old so I took it to Interstate Batterys & they load tested it & it tests like new. I've removed the starter & had it bench tested & it functions fine. I removed the negative battery cable & had a new end put on it (it wouldn't tighten 100%) so that is also be fixed. I replaced the clutch safety switch at the pedal & the starter still won't turnover. Replaced the relay in the PDC with the same results....None! The batt has 12.6V sitting voltage.....I'm out of ideas. All suggestions would be greatly appreciated!
Clay
rioredstang
Car: 1993 240sx SCCA ITS
Does the starter click when you try to crank engine? If so I think you have a bad winding on the amature. try tapping on the starter when it won't crank. I think you just have a bad starter.
dalt1
Car: 1995 240sx SE
Ignition switch going bad?
vancouverbc
Car: 1991 240sx
look up starter in tutorials in my signature. you are doing things the hard way.
Klits562
Car: white s13 coupe
rioredstang wrote:Does the starter click when you try to crank engine? If so I think you have a bad winding on the amature. try tapping on the starter when it won't crank. I think you just have a bad starter.
he said he got it tested.When your car doesnt crank does the starter click multiple times or just once?You said you had your negative terminal replaced so did you look at the exposed wire to make sure it wasnt oxidized? If you didnt then check if it is cut it expose new wire and put your terminals back on.also wht happened before it wouldnt start? You might have something drawing away energy from your battery when you try to start.When it does start does it start quick or really slow and drawn out.
Also very important question that you may of over looked.Is your battery in the trunk?
klaybus
dalt1 wrote:Ignition switch going bad?
No click
klaybus
Klits562 wrote:he said he got it tested.When your car doesnt crank does the starter click multiple times or just once?You said you had your negative terminal replaced so did you look at the exposed wire to make sure it wasnt oxidized? If you didnt then check if it is cut it expose new wire and put your terminals back on.also wht happened before it wouldnt start? You might have something drawing away energy from your battery when you try to start.When it does start does it start quick or really slow and drawn out.
No oxidation on the negative wire. Starts relatively fast when it was turning over. Battery is under the hood not in the trunk...
SIL_EIGHTY95
Car: 1995 240sx SE with a 1993 s13 front swap
had same prob with mine it could possibly be the ignition switch but my problem was with the security system try puttin the car in neutral and grounding the starter terminals with a screwdriver if it turns over check your ignition switch pretty expensive for a new one or just buy a push button switch
SIL_EIGHTY95
its only about ten ta twenty bucks at a parts store
Marahutay
Car: 1991 Nissan 240SX Fastback
my brand new starter wont turn over either, i have been using a rubber glove and touching the live wire going from the battery to the solenoid to click out the gear, and while its still touching that, touch the same wire to the other prong and the starter should turn over. it must be done in that order or your gear wont pop out and youll just end up spinning and burning out the starter.
otherwise, have you found a solution? i am still looking for one that doesnt involve me hot wiring the starter.
my starter did ONCE turn over normally. typical 240 behaviour.
