1995 240 only runs on starter fluid
alicbr
Car: 1994.5 nissan 240sx
2013 vw cc rline
Hey guys I have a 1995 240 w/ sr red top. Only runs on starter fluid but dies right after. I put in a new igniter, spark plugs, fuel pump, new battery and cas and nothing. I've checked all the grounds and still nothing. Thanks
Reason: Revise Title
PapaSmurf2k3
Site Admin
Sounds like your injectors aren't firing or you've got a bad fuel pressure regulator. Have you verified fuel pressure? Can you pull the fuel rail and see if they are spraying fuel while you crank?
alicbr
2013 vw cc rline
Hey papasmurf I got it running fires up first crank I had some build up on the spark plugs cleaned them off and now she’s good thanks for the help but she idles a little weird any advice
PapaSmurf2k3
Site Admin
Can you clarify/further describe "a little weird"? Maybe take a video?
alicbr
2013 vw cc rline
It goes from 900 rpm to 1300 up and down
PapaSmurf2k3
Site Admin
I'd look for vacuum leaks as a start.
