nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Wed Mar 12, 2008 12:53 pm
No, not having the same number of teeth won't cause any actual problems, but the ECU might throw a code.
It would hold up, but it will also gain and lose revs very quickly, which will make shifting tricky, especially in traffic.
Clutch and flywheel for $400? Without a pressure plate that might be doable, but it's going to be more than that most likely. Unorthodox Racing and JWT both make very good stuff, take a look at them.
Honestly, I'd go for easier mods first like a header (though you're definitely going to want a muffler and a resonator, it's going to be obnoxiously loud otherwise).
The SE-R is also a good platform for boost, if you're so inclined.
What do you want out of the car? If it's just a DD and your 240 is your performance machine, I wouldn't mess with the flywheel.
