1995/1991 ka24de
R2E4D0sx
Car: 240sx
Just wondering if a turbo kit for a 95-98 240sx will fit a 91 240sx. and would i need a lot of modifying to make it fit. its a Turbonetics kit has * Ceramic Ball Bearing Turbocharger (T3/T4 Hybrid or Custom T04E) * Spearco Intercooler System * Powder-Coated Intercooler Piping * Silicone Hose / T-Bolt Clamps * Exhaust Manifold - high carbon cast-steel with ceramic coating * Fuel / Timing Controller (electronic fuel / timing management system) * Fuel Injectors * "Evolution" Wastegate Assembly * "Raptor" By Pass / Blow Off Valve Assembly * Mandrel-bent ceramic coated Downpipe with closed-loop wastegate discharge * Intake System with Air Filter * All necessary Hardware, Hoses, and Fittings * Free Case of Turbonetics TS-1 Synthetic Motor Oil
Charlie240sxt
Car: 95 240sx SE Ka24det!!! 98 audi A4
it will fit the motor fine now the body on the other hand youll run into a few little things i'm not 100% on this but think the IC pipeing will be your biggest problem
Also side note if you have to ask this Q you probley need more time behind your comp reading about ka-ts before you go slapping one together
