1994 Strut Rod Bushing
Damicci
Car: 1994 Q45/President
Need a Strut Rod Bushing for 1994 Non Active Q45I did a search on google and RockAutoparts comes up with a couple available. I checked on IOS' site and couldn't find this particular part. It's to replace a bushing on a set of coilovers. Coilovers fit a 90-93 now i need to change just the bushings.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Do you meant the gaiters with bump stop?
Call IoS with your VIN to get a quote.
Damicci
Goes where the missing one is.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Ah, I bet they only come with the strut if the OEM strut even uses them.
unknown007
Car: White 1993 Q45 (G50)
They're coilovers that he bought from here im guess.
unknown007
Damicci wrote:Need a Strut Rod Bushing for 1994 Non Active Q45I did a search on google and RockAutoparts comes up with a couple available. I checked on IOS' site and couldn't find this particular part. It's to replace a bushing on a set of coilovers. Coilovers fit a 90-93 now i need to change just the bushings.
You should be able to push it our off the oem strut
Raxephon
Car: '04 RX8...for the moment...
Damicci wrote:Goes where the missing one is.
Those look a lot like the bottom of a set of Megans.
Damicci
That's because they are. I read a guy on here replaced the bushings with an OEM one. I don't remember if he re-used his or purchased a replacement. So that is why I am asking if there is a place to replace just the bushing. I know the OEM ones can be used and work fine but would like to try to buy them if possible.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Call Joe.
