Chingon - I am thinking they are Z32 brakes for the front and Stock USDM Rear as well. Problem is that if they are the wrong ones then I have to pay the shipping back to the states for a return and maybe shipping over again for the new ones or try to sell them and re-order.
Candela - Chingon brought up that the rotors should be the same but if you are saying they are the exact same as the Z32 26mm rotors then whay are the nearly brand new front rotors on my car 30mm?
Here are some of the measurements I took.
Front: Rotor Diameter = 280mm*Rotor Thickness = 30mm*Hat Outside Diameter = 155mm*Pads are Sumitomo SN258P E7X13
Rear:Rotor Diameter = 258mm*Rotor Thickness = 9mm*Hat Outside Diameter = 165mm*Pads are Sumitomo SN551P 8G02
**** I forgot to measure hat hight. Time to pull the breaks... AGAIN.
* All measurements are made with a tape measure so may be off a little bit.
So just by the replys I guess you can understand why I am a little worried about going with my Assumptions.
Thanks for the replies so far. Anyone else???
