1994 sentra electrical problem
stephenp55
Car: 1994 nissian sentra
i have a 94 sentra limited edition 5 speed 1.6liter once warmed up when i put a draw on the power such as hit the brakes turnsignals or lights it drops the rpms real low then catches back up and at an idol some times when i put a draw on it the car will stall also once warmed up it will idol around 600 rpm instead of its normal 8 or 9 the car also dosent want to start when its hot i am clueless as to how to fix it i tried new plugs wires cap rotor ignition coil and tps. Any Help?
PapaSmurf2k3
Site Admin
Has the alternator ever been replaced or tested? When was the battery last replaced?
How do the terminals look at the battery? Any corrosion?
stephenp55
not shure on how old but its not that its not charging because it has plenty of power to cranck every time you try to start it and the terminals are good there is no corrosion
PapaSmurf2k3
Site Admin
Well the alternator could be charging the battery just fine (amps wise), but could also be low on voltage. I'd get it checked out and go from there. Do you have power windows? Are they acting sluggish too?
stephenp55
no its all manual but what your saying males sence but would that affect the way it starts when its hot compaired to cold?
PapaSmurf2k3
Site Admin
Probably not, but you might have multiple problems.
89CoupeVG35
Car: 1989 Nissan 240SX Coupe
2000 Nissan Maxima GLE
1998 Nissan Quest GLE
1998 Nissan 200SX SE
Make sure you check the terminals really good. They may look good but overtime they do wear down. I had this same problem and it turned out to be the entire negative cable. I went to home depot got some 4 gauge wire and connectors and redid the negative cable. Problem fixed. Try that first. It is a cheap way to start also.
