1994 sentra 1.6l swap sr20de?
cnbmurphy
Car: Nissan Sentra 1994 1.6l
I have a sentra 1.6l se? and i was wondering how hard it would be to drop in the sr20de into it whhat would i have to change would it bolt up easy.? if anyone knows post some tips would be greatly accepted :-D
ProudNissanFreak
Car: 2005 Imaginary WRX STi, 2003 Civic
welcome to nico!
secondly, there's been a ton on this stuff as its one of the most common swaps. im sure searching would definitely help. but from what ive heard its a pretty easy swap but you need to build new motor mounts and a couple of other things.
nametakennow
Car: '06 MINI Cooper S
Don't need to build to motor mounts, just swap the crossmember for the front/rear ones from an SE-R.
Check out the Table of Contents. There are a couple of threads in there (including a GA->SR FAQ) that should get you started.
ProudNissanFreak
nametakennow wrote:Don't need to build to motor mounts, just swap the crossmember for the front/rear ones from an SE-R.
Ok, I was misinformed then. Thanks for clearing it up
