1994 sentra 1.6 clutch issues
apostrophe28
Car: 1993 300zx Twin Turbo
when i press in the clutch the pedal goes to the floor..i can lift it back up and it stays but if i touch it it clicks back to the floor....im gussing its either a broke clutch cable or slave/master clutch cylinder (not sure if i have a hydraulic clutch system )
-1994 sentra le 1.6 ga16de , 130k miles
anyone know where i can find an online guide to replacing either the clutch cable or slave/master cylinder? (if that turns out to be the case)
MaximA32
Your best bet is to pick up the Haynes manual for it. It's under $20 and it has saved me a few times. It also could just be that you have air in the system. I would try to bleed it out first and see if that changes anything.
