1994 SE/XE Pathfinder Instrument Clusters Interchangeable?
DVD7000
Car: 1994 Nissan Pathfinder SE 4WD
I found a local parts dealer only a few miles away that has a 1994 (XE) cluster without the dual trip (LCD) recorder in the lower left corner, but the other gauges are the same. Would the other gauges work correctly? Or do I need to replace mine with the exact same cluster configuration?
I wouldn't care if the trip recorder function didn't work.
Mine (SE) with Dual Trip:
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
If i remember correctly the xe versions were the really stripped down basic ones, so it may be missing warning or display lights for your se as it has more options.
DVD7000
Problem fixed. Found a used instrument cluster for $53. Installed and working.
Now I have to get the odometer mileage difference reported to DMV or whoever needs to be notified. I read somewhere that when you change a cluster, and the odometer reads more than is actually on the vehicle (was 71K , now reading 125K) you can get a sticker to put on the door stating the change.
