1994 QX4 Sunroof leak
akers912
Car: 1999 Infiniti QX4
I had a lot of rain during the night and when I got in my car this morning I looked up and saw a small wet area in the back right corner of my sunroof. I always make sure it's closed all the way and it was during the night. I did notice the right arm that helps push the sunroof back is pretty rusted, but I'm not sure if that has anything to do with it. I'm going to inspect more of it later but has anyone else had this problem, or have a solution to resolve it?
Thanks,
-Michael
Platinum04
Car: 2004 Nissan LE Pathfinder
Had a similar problem, The QX4/Pathfinders have a roof drainage system under the roof liner. It is a act of congress to get to it but you need to check all the drainage points for the entire system because it may be clogged with debri or something.
