1994 Q56????
rabsusa
Car: 1995 Silver mist Q45t 79 k miles
1994 Black Base 89 k miles - spares car(trans broke)
greetings all,
will Q56 engine fit in Q45?? i m starting to see some cheap breakers now for sale tht makes this look very tempting
:naughty:
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Im sure it will fit fine, but it wouldn't be an easy swap.
If you wanted 400-450HP, it would be considerably easier to turbocharge or supercharge the VH45.
Brew Q
Car: '92 Q45 91k miles, '05 FX35
past: '99 740i (r.i.p.), '92 Maxima SE, '89 Maxima SE, '04 FX35
If you know how to weld I'd go the LS motor route..
5.3 and 6.0 GM truck motors can be had cheap in junk yards and all the LS parts (cams, intake manifolds, etc.) fit. They are easy to tune too. The 5.3's are popular for turboing and the 6.0's there's some of both. Plenty of guys making crazy power with either one.
LS1tech.com - plenty of info and swaps - for example there's a sleeper 540 with an LSX in it on there - and yes all the electronics work, speedo works etc.
of course if you are a Nissan purist I may have just offended you! :sad: Don't get me wrong, I love Nissans - it's all I've owned, but the maintenance, $ and HP aspect of the modern GM V8's is crazy.
Personally, I'd turbo a 6.0, drop it in an early 90's Q and have a 600+WHP Q... of course you'd have to cut up the rear wells and put gigantic tires out back :chuckle:
N/A Q45
Car: 94 Q45
Or just build up the N/A VH4.5DE-
Brew Q
but that's already being done :chuckle:
Q60 - a Q with a 6.0L V8 :naughty:
Here's a 540i with a supercharged 402! :woot: dyno sheet at post 75 - 532WHP and 575 TQ!
http://ls1tech.com/forums/conversions-h ... leted.html
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Brew Q wrote: Here's a 540i with a supercharged 402! :woot: dyno sheet at post 75 - 532WHP and 575 TQ!
Wow, almost as much as a stock 4.4L M5/6 engine! Why not a tractor engine? Those have to be even larger! :facepalm:
Brew Q
S63B44Tü, which produces 560 hp (418 kW) and 502 lb·ft
Actually a bit more HP than what a new M5 motor puts out and more TQ. Plus an older 540 would be considerably lighter.
rabsusa
ya i m not into cutting & welding, too much work, if 56 fits, i d rather do the re wiring to make it run,
thanks to all,
elwesso
2007 BMW M Coupe
You'd still have to do plenty of cutting and welding to get a VK56 in there.. You'll have to make new engine mounts and exhaust minimum..
Turbon8er
Car: 93 RPS13 -Rojo
95 Infiniti Q45
77 Datsun 620 KC -Puddin' Tang
maxnix wrote: Wow, almost as much as a stock 4.4L M5/6 engine! Why not a tractor engine? Those have to be even larger! :facepalm:
:lolling: :rotflmao
a Detroit 6v92 Turbo would decimate all... after about $10grand... :rotfl
Seriously... buy the VK56. Hack up your frame and bay all to crap to fit its fast-food-eating trailer-park wide a** in there, spend thousands on custom parts to make it work, then come back and tell us how it will destroy the VH45. Of course it will. I know that VK is stupid powerful/fast in the big Titan, so i can only imagine it'd be balls out in the Q.
BrewQ- BLASPHEMY!! If you put an American motor in the Q i will drive to TX JUST to slap you :slap:
Brew Q
lol, nope Suzie is staying her fine self. At some point I'd love to turbo her, but that'll have to wait until the student loans are gone, ugh.
Now a turbo VH 3rd gen maxima? a 3200 lb car and 400+ whp :chuckle:
