qsiguy »
https://forums.nicoclub.com/qsiguy-u27015.html
Fri Apr 29, 2005 6:01 pm
I'm having the same problem. Prior to this I had the alternator regulator fail and the first indication of this problem was the SLIP, TCS OFF, and the ABS lights on. I wired my Fluke multimeter to the lighter while I was driving to see what the voltage was and it went all the way up to 20 volts! I got it to the shop where the alternator was replaced only 7 months ago to have it replaced under warranty but I had to drive about 20+ miles with the high voltage on the system. The alternator is fine now but I have noticed that once in a while the SLIP and TCS OFF are coming on but not the ABS light. Checked the voltage when this happens and it's normal (13.5-14 volts). I am wondering if something "fried" due to the high voltage.
That photo that is posted....that's the cell phone "brain" for the OEM cell phone...
qsiguy
