Wooman70 wrote:1. EGR + EGR valve gasket replacement ---> for rough idle and poor gas mileage.2. Belt Replacement ---> it's just needed that because it's old3. Valve Cover Gasket Replacement ---> same as above reason plus leak4. Spark Plugs Replacement ---> old5. Power Steering Pump Replacement ---> leak6. Fuel Pump Replacement ---> the infamous "humming" noise7. Valve Guide Seal Replacement ---> blue white smoke in the morning8. Rear brakes needs new pad ---> getting low at 25%
The shop quoted me around $3000 for just items 1 - 6. Item 7 alone is $3000 and #8 is around 300.
I met up with David Saturday to evaluate his Q.
The idle is rhythmic miss, like a big vacuum leak although we didn't hear any hissing. the EGR function is correct, the valve starts to pulsate around 1500, manually opening the valve will bring down the revs or kill it.however, his aac is not under ecu control. i adjusted it out 1 complete turn ccw, and idle only gained about 50 rpm, so i think he has serious plenum gunkup. wiggled maf connector, no change. didn't take apart. maf connector has definitely been reworked at some point.2. and 3. confirmed.4. don't know. rough idle is also sorta like broken plug--prolly due for change although i noted several missing ornament screws over the coil pax, so someone has gone in there sometime.5. ps pump is a gooey mess. both rack boots torn.6. fuel pump is definite, the fpcu still has at least 2 speeds, as i could hear it kickup a notch while he cranked it.7. blue smoke imo is most likely raw fuel. i didn't see it cold, but on warm restart, it would puff some black when first started. due to the very rough idle, lot of unburned fuel.
looked inside valve cover, and cams are reasonably clean.some injectors (looks like 1,2,7,8 but not 100%) have been changed.
power is alright above 2500. no odd engine noises.trans shifts great for 166k.
active is flat. diagnostics read code 45 low fluid, even though fluid level is fine.
my evaluation is that he is looking at about 6000$.he likes the car and would like to keep it.
I'm sort of speaking for David and encouraging some additional thoughts/critique. I personally would also appreciate some other inputs on his rough idle as supplimented by my data today. I reminded him that he could drop 6 large on it and still have a host of issues that pop-up in the near term.
