rml85 »
https://forums.nicoclub.com/rml85-u161204.html
Thu May 20, 2010 2:39 am
I have a 1994 Q45t with 126,673 miles on it. In the last few days, when I start the car up, everything appears normal, but within a few seconds, the tachometer will drop down to zero, and the engine will shut off. The Check Engine, Oil, and HICAS lights come on for some reason. Sometimes after this happens though, the needle on the tachometer will rise again, and sit at just below one, where it would normally sit, other times, the car just dies completely. Sometimes it takes 3 turns of the key to get the car running. Also, it has done this once while sitting at a red light too. The car puts out a smell of gasoline also when this happens.
I recently had both the MAF sensor and the Fuel Pump replaced by Infiniti of Tucson. The car also has full levels of all fluids such as oil, ATF fluid, power steering fluid, etc. The car runs fine when moving. Like I said this only happens at startup and very rarely if I am sitting at a red light. Could this possibly be either an idle problem or a bad fuel injector, or something much more serious? Or maybe even the Arizona heat has finally took it's toll on my Q. I am thinking I would probably need to have a diagnostic test performed, but I was just wondering if anyone else has had this kind of problem? Please, I appreciate any advice, I can't really afford another vehicle right now, so this needs to last for the time being. Thanks.
