1994 Q45 Vibration around 1900 rpm
tegva
Car: 1994 Infiniti Q45 87K
1994 Infiniti Q45 320K
1979 MGB
1991 Alfa Romeo 164
Could use some advice on a problem on my 1994 Q45 with 87k miles. Recently changed injectors, fuel pump, driveshaft and have two continuing issues. The car is sometimes hard to start but maintains fuel pressure and also has a vibration around 1800 rpm. May be two separate causes or one. I have a running parts car so have readily available parts to swap things out to see what the issue is but not sure what to try next.
sandydennis11
Car: 1996 Infiniti Q45 176k miles
purchased new in 1995
Did you replace the fuel pump control unit. Same thing with my '96 for hard start.
BTW, do you want to sell the Air Mass Meter Boot from your spare parts car?
Let me know.
Sandy
goody90q45
Car: 1992 Infiniti Q45 (sold)
The 3rd engine mount, AKA transmission mount, will put out a vibration in this rpm range when they start wearing out. It's an easy repair but a replacement part may or may not be available.
Q451990
You said the car is "sometimes" hard to start. Can you find a pattern? Years ago, I had a leaky lower o-ring issue with my injectors - or maybe the actual injectors were bleeding down. The car would start fine after sitting over night, or in a few minutes after turning it off - but from sitting about 10 minutes to about 5 hours, it would start hard, and smoke a little.
tegva
1979 MGB
1991 Alfa Romeo 164
On my last Q45 I did most of the work myself. This one I had someone replace the injectors and transmission mount but you have all confirmed to me what I should be looking at closer and I'll do it myself this time. I checked the control unit. The other question I have is that I know if the Q is started when cold and turned off quickly it will be hard to start and will need to floor it to get it started. Which is almost like what is happening now. Is there a sensor or valve in the air or fuel circuits that I should look at?
Q451990
What you're describing sure sounds like flooding, which is usually a bad/pinched lower injector o-ring. If it's bad enough you can hydrolock the engine. There's a TSB somewhere that Nissan published to test leak down. I'll see if I can find it.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
I think Goody is on the trail for the 1800 rpm vibration. If you get that in PARK (yes really), then it is the 3rd mount.
BTW, what did you do for a driveshaft? 1-piece aftermarket?
tegva
1979 MGB
1991 Alfa Romeo 164
I bought a 1-piece aftermarket aluminum from Driveshaft Specialist Inc in San Antonio. Fit right in and is much lighter. Looked for the vibration in park and there is something there. Will take a closer look at the transmission mount
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Congrats on the 1-piece driveshaft! I have been considering doing this on the BlacQ 95. interested to know if your 40mph vibrations are less (how much).
besides the 3rd mount, there are rubber pucks that hang the exhaust just aft of the 3rd mount. those can contribute as well.
p/n is 20610-60u00, unfortunately, they appear to be obsolete.
p/n for 3rd mount is 11320-60u02.
Drake57
Car: 1992 Q45, 1990 Q45 (parts), 06 Sportster XLC, 85 XJ6, 08 4Runner, 89 Suburban 4WD, 75 Honda CT90
goody90q45 wrote:
Mon Feb 11, 2019 6:44 pm
Words of wisdom - Replace the rear transmission mount - I just did so on my 1992, and it completely eliminated a nasty shudder that happened when engine RPM hit 1900. The shudder itself seem to be 10-15 Hz, some subharmonic. The car is much smoother & more comfortable.
I never suspected the mount, but it eliminates the trembling, this is what I installed: //www.rockauto.com/en/catalog/infiniti,19 ... mount,8616
In my case, the shudder appeared only after putting the car back on the road after a 4 year period of sitting up. The old part appeared to be sagging, and the rubber webbing was partially cracked.
So hats off Mike, it makes a really nice difference.
I have a slight ATF leak, which I suspected was the transmission tail shaft seal, but the shaft and housing are totally dry, though the connector cluster at the tail shaft are dripping, so I think connectors are the source of the leak. Each time I raise the front of the car for service, while leaving rear wheels on the ground, ATF drips from the connector cluster. It's not a major problem, but I hate the smell of burning motor oil. Has anyone fixed this, or know how the connectors seal?
I also found one of the exhaust mounts that bolt to the transmission cross member is sheared, so if I can locate a replacement, that is next. Good week, all!
Q451990
Thanks for the update!
tegva
1979 MGB
1991 Alfa Romeo 164
If anyone has to replace their transmission or 3rd mount like I did you may find that an OEM is hard to find. I purchased two new replacement mounts that didn't eliminate the vibration before trying Nismo 11320-RS541 Upgraded Transmission Mount for Nissan 300ZX 90-96 Z32 . This Nismo mount fit right in and vibrations were gone.
Q451990
tegva wrote:
Tue Jul 23, 2019 8:36 am
That's great info. Thanks!
