No, all I hear is a little click behind the glove box when I try to change the fan speed.Lokim wrote:Can you hear the blower motor running?
qship96 wrote:Or just supply 12 volts and ground directly to blower motor terminals.....if no worky, replace fan motor, a simple 10 minute operation and very common, I would bet it has already been replaced once depending on the number of miles on your Q { they generally last 150,000 miles from BRAND NEW- many replace with a junkyard used part, and then its remaining life is a crapshoot at best}
