elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue Nov 13, 2012 9:59 am
More commonly the TCS actuators (under the hood with the fluid res) fail. I've never heard of a TCS pump failing. The TCS actuator failures aren't horribly common, but they're getting more common as time goes on. Normally when the TCS actuators fail is they make a buzzing noise for about 30 seconds, and then the lights come on.
I would recommend you replace the TCS actuator. Usually finding a used part is a good bet since they don't fail super often. Replacement isn't really bad, be sure you have some flare wrenches to get the brake lines off (don't use open end wrenches, you'll round the flare nut).. You'll have to take the inner fender liner off to get to a couple bolts inside there, but otherwise it's simple.
