1994 Q45 Traction control system Actuator (TCS)-used. Help needed.
osas
Car: Infinity Q45 -1994
Hi fellows, I am new to this but not new to dealing with my infinity. Can someone please help me with information on how to get a replacement for the TCS actuator of my Q45 infinity 1994? I really need it to get my car back on the road. Help please. Send information to [email protected]
Or can anyone advise me on a solution to the SLIP & TCS light comimg on and staying on after the noise from the hood stops? I really need to fix this, and need some help.
Osas.
Modified by osas at 9:34 AM 12/12/2004
osas
Osas.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I would recommend you do a search... I have a used TCS actuator and ive already promised it to another NICO member...
You need to check your TCS codes... Please search
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
First thing to do is run the diagnostics and pull the error code to see what is causing the fault. It can be (order of probability) 1) Relay by the battery,2)secondary throttle position switch
Q45tech
Or just drive it the 35-40 {?} miles to I285 exit 15 and let T3 look at it.404 - 794-7700. For $70 they'll list all the faults about every system they find and give you a wish list just as they do for a prebuy inspection.
