1994 Q45 T sunroof
filmman
Car: G35 Coupe
Sunroof opens ok but when it tries to shut it stops about 3 inches short. You can then manually help it shut . Took it to the dealer and they want $1800to fix it. I can't beleive that it anything major since the motor works and it operates to the open setting just fine.Any help would be appreciated.Thanks,Tom
Q45tech
Motor safety clutch is slipping because currently or in the past the rails were under lubricated.......friction and trash in channels.
Search the forum for how to dissassemble and adjust the clutch.
filmman
Car: G35 Coupe
Thank you for the prompt response and info. I will try it this week.Tom
Q451990
Make sure everything is clean and lubricated first. If that doesn't cure you - here's my thread on the clutch adjustment.
Heath
http://www.nissaninfiniticlub....lutch
Need4Speed
Car: Unique Cars, Sailing, Shooting sports
Clutch adj. works wonders......removing the headliner takes more time than the actual clutch adj. (took me 1.5 hrs... first timer)
Good luck,
Andy
qship96
Car: 1996 Infiniti Q45
what is the procedure to clean the rails?what lube do you guys recommend?now that it is warm i would like to do this service to prolong the life of sunroof.thanks.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Thin coat of white lithium grease on the rails. Nissan (hence Joe) has an aerosol can of lithium lubricant that is ggod for this and hood hinges.
