Since you're in the business, I have to ask ...irax wrote:ok guys, with racks do not buy cheap, for a quality rebuild it is worth the money. A lot of times when companys offer a 'life time warrenty' do what we call in the business a "spray and pray". What that is, is when they get the rack they only replace the seals that are worn out. Where as when we get a rack we replace all seals, screws, joints, bolts everything that COULD ware out is replaced. My company has been rebuilding racks for little over 18 years now. Our racks will come with a 3 year warrenty. Therack will run you 310 (Ask for Abe*me* and mention NICO and you can have it at the sweet price of 265) + a 150 core deposit. Give me a call I promis I will take care of you. Plus you get free shipping.
Abe
Meridian Rack & Pinion800-845-1225
ASK FOR ME!
ITs gotta be a hose thats leaking, IMOhst wrote:Thanks for the quick replys guys, I'll give the lucas a shot, but it is leaking a sh*t load, about a quart a week. It may be beyond all help. Abe I may be giving you a call next week!
If I'm not mistaking, 90-93 steering rack is different from 94-96. There was a discussion a while back and here is what I remember: (One real valuable improvement for a 94/96 is a 90-93 steering rack.A bit tighter and sportier feel.Fred..)Rex wrote:Since you're in the business, I have to ask ...
Have you heard about the differences in the steering racks between the early Q's and the 94-96's? Supposedly, Inf only offers one part number now, but the earlier ones were a different P/N before.
There is no HICAS in 1995--1996. Meridian is Joe's supplier for non-OEM racks. If you have a good rack (rack and pinion are machined to 1/10,000 of an inch), you may want to consider the seal kit. Requires skill and a decent shop bench to install correctly.irax wrote:94-96 HICAS is the same as the standard.
It is 2.6 turns lock-to lock for a 15:1 ratio. Steering gear is PR26SE.RobertsnewQ wrote:THEN the std. got the 3-turn rack & the active got the old 2.6-turn rack. Or vice versa (it's not clear from the data out there. ANyone have a 95 shop manual?)
Well the Lucas stoped the leaking, 3 bottles at 9 bux a pop. Not to bad. But I do need to replace the boots ASAP. Where is the best place to order these from??SDQ45 wrote:You may just need to replace the boots.
