1995Pathfinder »
https://forums.nicoclub.com/1995pathfinder-u4366.html
Mon Jun 16, 2003 6:54 am
This past weekend I changed my rear brake pads and I noticed that the left rear pads were not worn down equally on the same axel - the pad was worn down on the bottom, but the top of the pad looked like it wasn't even touching. I removed the caliper assembly which included the torque member to take it apart on the bench and clean it up. I removed the lower pin bolt without any trouble then tried to remove the upper pin bolt, but could not. In fact, I could not even turn the bolt so I mounted the caliper and torque member assembly into a vise to see if I could turn the upper bolt. I managed to turn the bolt, but no way could I get the pin out. I thought maybe the pin was to push out once unscrewing the threaded portion, so I even tried to hammer it out with a punch and that did not work. Please let me know if the caliper is suppose to float on this pin like the front does. The right rear was also stiff and I could not remove that either. I did what I could and had the rotors cut and assembled everything. The car drives fine, but I smell a burning (smells like something electrical burning) and I assume that this is a combination of the new brake pads, plus the rotor heating up. The left rear wheel is very hot and the right rear appears fine. I can not believe that the caliper could slide on the upper bolt with as tight as it is and therefore the uneven wear on the pads. Here is the question. Should the caliper slide freely on the upper bolts for the rear wheels like the front? And if so, how in the hell do I get that pin out? Can I screw it out all the way and then hammer it out with a punch? I was afraid hitting too hard when I had it apart for the fear of breaking something. Please let me know. I need some help. Thank you.
