szhosain wrote:It is also part of the air flow management under the car. Helps with engine cooling, I suspect. So, I would certainly not leave it off permanently.
Z
Absolutely... at least on the 90-93, running it without this cover stopped in traffic in very high ambient temperature (over 100F) can cause overheating... at least that's my theory.
Stand with your toes under the front bumper after it's been idling for a while with the shroud removed and you'll feel what I'm talking about. The hot air that would normally be directed more toward the rear of the engine bay is blown directly down - only to be pulled right back in through the front of the radiator... not good!
Heath
