t61bh6o »
https://forums.nicoclub.com/t61bh6o-u16255.html
Tue May 11, 2004 11:53 am
Thanks for the tip on the ECU. I will follow the instructions on other posts to check the codes since I shouldn't expect that the check engine light will indicate an error that the ECU picked up.
Since my first post, I started the car and at an idle grabbed a hold of the large intake hose running from the maf to the throttle body, and slowly put pressure on it up and down... the car stalled.
I pulled the hose off, and all attached hoses, inspected for any cracks and re-attached all hoses TIGHT... Took the car for a 20 minute ride, stop and go and high speed, and all seems OK no surging no stalling.
Will report back after the morning commute.
Thanks.... Any recommendation about grounding the MAF?
