1994 q45 front passenger suspension problem making noise all the time
ponzy
Car: infiniti q45
>>>>> i'm a newbiee q45 owner. got a problem with the front right suspension. it makes noise(like slowly opening an old door) all the time when running... i had just replaced the front struts (both)( cause my mechanic told me the front struts worn out already-- paid $800 dealer-part-only and $100 labor), the problem still there then returned to him and R&R front brakes and rotors ($215 parts and labor)but still still makes noise while running... and now he's telling me to change the uppper control arm and both strut bar for $650 parts and labor. i had it im spending a lot of money but it seems the problem still there...can anyone help me..to giveme an advice thank you... >>>>> i know just a little bit on car parts/know-how>>>>
ponzy 1994 q45 102k
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Did you replace all the rubber when you replaced the shocks? Blues or blacks?
I think you need to get acquainted with http://www.infinitipartsusa.com
Presume your mechanic has no particular G50 expertise?
You have found the right place to learn about your car, so dig in and start reading. Particular attention should be paid to posts by Q45tech.
With a torque wrench, some sockets, an FSM, a jack or a lift and the posts here you can do it yourself and save about $400 on the upper links and tension rod bushings (have them pressed in).
Modified by maxnix at 12:22 AM 11/8/2006
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
Were the strut mounts replaced? They would make noise, as well as sway bar end links in addition to the other parts you've replaced . If its any consolation, the parts you're replacing are are all wear items so you haven't "wasted" any money yet. Think of it as an investment.
Q45tech
Every 13 year old used car needs almost every piece of rubber replaced.Usually the window, hood and trunk and door moldings are ok. Sunnroof iffy.
That leaves a hundred other rubber things!
I would have taken it to dealer to get a full and complete list of things wrong.............paid them for their trouble [maybe have them do a few things] then had the list evaluated for triage.
ponzy
Car: infiniti q45
thanks guys for the advice.....i've foud quite a few topics about these....is upper link the same as the upper control arm; and tsrut bar is the same as the sway bar, my mechanic is telling me?thanks...
ponzy 1994 q45 102k
ponzy
Car: infiniti q45
can someone help me on how-to -step by step to check rubber bushings, upper link sway bar/strut bar etc, re: front passenger suspension; including diagrams for 1994 q45 standard and proper tools to be used. cause right now, i dont have any resources to bring and have it check to the dealer cause it's expensive. thank you so much.
i was hoping i can do that and inspect over the weekend.. 'm not a mechanic-type but i know how to follow proper instructions. thnks again...i've learned so much here so far....
MORE POWER TO NICO CLUB!!!!!!
Modified by ponzy at 12:51 PM 11/10/2006
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Most of that is in the FSM, and maybe some in TSB.
You might consider
Keith Vanmeter Auto Repair(856) 415-2022395 Wenonah AveMantua, NJ 08051
mcastro
Car: 1995 Q45
A common issue with the G50 are the bushings wearing out in the upper link, which will cause a creaking sound when your suspension is being excercised. If you look in the wheel well, above the tire, you will see the upper link which hovers over the inner part of the tire and connects to a bracket on the wheel well. You can often alleviate the creaking sound by spraying some WD40 (or equivalent) in the seams on the bolts which attach the upper link. If the noise goes away, you've found the culprit and you should plan on replacing the upper link. (this is a regular maintenance item).
The part runs about $90, and you should replace both passenger and driver side. It is an easy do-it-yourself job, just 2 bolts. If you search the forum, you can find instructions on replacing the bushings only, which can save you $60 per link, but it is a little more complex to get it done.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I dont thinky ou can replace just the bushings.... Its best just to get new links from joe and call it a day for the next 30-60k.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
mcastro wrote:The part runs about $90, and you should replace both passenger and driver side. It is an easy do-it-yourself job, just 2 bolts. If you search the forum, you can find instructions on replacing the bushings only, which can save you $60 per link, but it is a little more complex to get it done.
Never read of a bushing to matchthe ones on the upper links, but texasoil did affix zierx fittings to lubricate the bearings which extends their life.
Modified by maxnix at 3:18 PM 11/14/2006
mcastro
Car: 1995 Q45
You're right, Wes....I was thinking of the tension rod bushings...
ponzy
Car: infiniti q45
thanks guys for the advice... as of now i havent done anything so far re: suspension. so far i cleaned my MAF and TB (thanks for the Q45.org tips) as i starting to feel a rough idle especially when on break and on first gear and firing like below 800 rpm. when on neutral or driving 10 mph or more rough vibration disappears. do you think that the problem on my suspension contribute to the rough idle or maybe there's something wrong with the fuel injection?. the car has 102.3k and they change the no.3 fuel injection last april'06 at 97.5k (from the dealer). do you guys think it could be fuel injection? ive searched the archived forum and most of them they suggested of rough idling secondary to: a) maf b) TB c) fuel injection. so far i've cleaned the maf and TB but still there's some feel of vibration(though it lesses a little bit and drives a little bit faster i guess) as i described above. where could i buy the FSM (factory service manual) for my car 1994 infiniti q45 standard suspension? ive tried searching on infiniti of scottsdale but it always give me a zero search on that partand do i really need to change the transmission filter and gasket? Is most mechanical procedures/ maintainance on the FSM ?
ponzy
Car: infiniti q45
besides the FSM (bible of q45) whatelse do i need most when it comes to tools or diagnostic parts, on maintaining the q. it has a very low millieage for a 1994 model. i really wanna keep my car good and running doing it on my own that having it serviced for overcharged labor costs. thank you so much...ill send some pic next time...
goody90q45
Car: 1992 Infiniti Q45 (sold)
ponzy wrote:Where could i buy the FSM (factory service manual) for my car 1994 infiniti q45 standard suspension?
Free download of the FSM:
http://phatg20.net/modules.php...id=62
ponzy
Car: infiniti q45
thanks goody....
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
ponzy wrote:besides the FSM (bible of q45) whatelse do i need most when it comes to tools or diagnostic parts, on maintaining the q. ..
You need the TSB also, and to read every post by Q45tech on this forum, and follow the links.
There is a composite of his posts from the Yahoo board in an attached text file in a post in Infiniti General.
ponzy
Car: infiniti q45
i've just been to a different regular mechanic. Re: right suspension, and he told me ---- right side is lower than the left side (could be the spring back and rubber bumber or dust cover and i should change both of them. ) he's gonna charge me at least $200 not to include the parts and other bushings he might encounter that needs to be replaced. the left side is in toe out position which suggests lower suspension (spring back). That's gonna be 170.85 on each (spring and bumper or dust cover -- from Scottsdale)). A total of $541.70 parts and labor. Not including other bushings and labor for that. I wanna do it myself but when i looked on the FSM there's so many tools that i dont have. do you think the price shown above is worth it or is it better to go to the dealer have them do the job. i am just kinda hesitant on doing that cause i've heard they're charching too much. THANKS AGAIN!!!
Kashka
I know this is an old post from 2006 but I must reply in the hopes that someone else with a Q will be as fortunate as I to have found this site and an answer to a very persistent problem that had 4 mechanics stumped. If you have a first generation Q as I do (1994 Q45t) and hear a creaking sound, like a ship listing or an old door squeaking coming from the front-end suspension area of your car you might just have blown upper link bushings. As per the excellent advice I found on this site I took a leap of faith and purchased two upper control arms (left & right) complete with bushings and had them installed by my mechanic. I am now driving my Q in blissful silence. Thank You! Thank You! Thank You! NICO my 3 months of wrong diagnosis are over. By the way I purchased these parts cheaper than my mechanic could get them from Partsgeek online. They got me the parts in two days UPS ground from their east coast warehouse; I live on the west coast. I found Partsgeek.com to be fast, cheap and professional. I hope this helps. :crazy:
qship96
Car: 1996 Infiniti Q45
I smell a shill
sandor
Car: 1994 Q45, 1998 Chevy 383 stroker, 2001 CBR 929rr
My q had the same symptom and I thought it was worth a try to take apart the upper bushings to clean and grease. It's been 7 years and 80K with no noise.
