Read very useful information regarding fuel pump/fpcu issues. After having the pump replaced (and not solving the problem) I found you guys and it appears that the fpcu also needs replacing. I can see the fpcu from the trunk but it appears that I must access the screw holding the bracket in place from the back seat.
Can you give me specific instructions about getting the back seat (vertical part) unstuck and removing the sundeck (back shelf)? I am assuming the screw is under the shelf.
Appreciate the help.
