1994 Q45 AC just quit working
Jmanolinsky
Car: 1994 Q45a
Hey guys,
The title sums it up. The AC was working yesterday and today it is NOT. I noticed when I ran an errand this morning that it didn't seem to be cooling as well and this afternoon after work it wasn't working at all. I've checked the fuses and the relay and they seem OK. I swapped the AC relay with the cruise relay. I checked the compressor and it is turning when the AC is switched on. Any ideas? It is much too hot to go without it.
Thanks in advance,Jman
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Theres many things you can check, but knowing the AC pressures would be a great start. That will help us indicate what is wrong...
Any work ever been done on the AC?
Jmanolinsky
Car: 1994 Q45a
No work has been done in the 7 years and 120K out of 174K total miles that I have owned it.
Jman
elwesso
2007 BMW M Coupe
Does the AC compressor come on....? Does it make any weird noises?
Still, without and pressure readings we're just shooting in the dark.
Jmanolinsky
Car: 1994 Q45a
The compressor comes on and sounds normal.
Jman
VA99Q45
Car: 99 Infiniti Q45
Try to charge the freon yourself. If it hold up till next year, then great. Else you just out of only $10.
I had similar problem w/ my car at the beginning of summer. I fixed for less than $10. It still works great.
Jmanolinsky
Car: 1994 Q45a
Yeah, I am going to put some gauges on it and give it a shot of 134.
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
I thought it was R14?
