elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Fri May 16, 2014 10:53 am
Welcome to NICO!
Looks like you've got a pretty ambitious project going on. The manual trans Q is a great vehicle, my Q has about 230k miles on it (almost 100k on the manual swap) and it was great...
To cut to the chase, I believe the Z32 and Z33 transmission has the same spline pattern on the input shaft in the trans. Don't quote me on that, but I think so. In that case, you'd be able to use a complete Z32 or Z33 trans. In either case, you'll want to match the pressure plate to whatever flywheel you use, and whatever clutch disk to the transmission...
I'm not sure what you're talking about with the Z33 3rd member? a 2009 trans has 0.794:1 6th gear, as does the 2003 trans.... The Z32 trans has 0.752:1, and the stock Q45 has 0.694:1. On my setup, despite the higher gear ratio with the Z32 trans, I noticed a slight increase in MPG. With the Z33 trans, I'd expect a wash at best..
At 70MPH, stock Q45 will be running about 2200 RPM.. With a Z32 trans, about 2300 RPM, and for a Z33 about 2500 RPM, so it's not a huge difference.
I don't usually recommend the lightweight flywheels on these swaps, primarily because I've seen a lot of people have issues getting them to work right.. Not really sure why, but that's the way it is... I use a stock flywheel on mine from an N/A. Another thing is a lightweight flywheel will have a lot less effect on a V8 than a V6, I4 or I6 because the flywheel is a much smaller percentage of the total rotating mass.. Therefore, I don't think it's worth the hassle.
I used a Z32 brake pedal and a pathfinder clutch pedal... It really doesn't make a whole lot of difference what pedal you use as long as it's from a Nissan because you're going to have to modify the crap out of it to get the pedals to end up where you want. By using a Nissan part the master cylinders will bolt up fine, so less work there.
I use one of those little Dakota digital speedo calibrators.. It was about $100, I hooked it up right where the speed sensor comes into the car, and it's worked great... Really easy to use. My reverse lights also work.
You will definitely have to re-work the exhaust manifolds some, mainly removing the pre-cats.. Even then, the exhaust goes very close to the starter on the passenger side...
People have a tendency to trivialize how much work this really is, and I think it'd be worth a close look to see if it's really worth it... An automatic transmission with a shift kit and torque converter is a heck of a lot of fun, and the performance is pretty much on par with the manual trans..
I also have done nothing to have an E-Brake. I live in Indiana, so I don't worry about parking on hills. An E-brake would be basically impossible to do and make it look correct.
