Q45inNH »
https://forums.nicoclub.com/q45innh-u218857.html
Sat Apr 20, 2013 5:27 pm
Hello. I purchased a 1994 Q45 with only 88k miles from a friend of mine at work. It was his father's, then his. He said it the only issue was that it occasionally did not shift out of 1st. The price was right. I've had the car for 5k miles and the transmission did not shift out of 1st just twice. A concern, but manageable. The CEL light then started coming on after driving on the back roads. I drive 48 miles on the hight way to work and back each day and the CEL does not come on. Only on the back roads, does the light come on - after a few miles. Turn the engine off and the light will stay off for a few miles, but then comes on. Because for the last 15k miles, regular 87 octane gas was used, I tried the Chevron textron, Guaranteed to Pass, and Lucas fuel system cleaner, think that the system needed a good cleaning. No luck
This past week, the "transmission malfunction" indicator came on at start-up, then went off after a few seconds. I took the car to AAMCO ( 100 yeards from home) and they said the only stored code was for the EGR valve. I reviewed this site - lots of good info - and had them clean the EGR valve & sensor, as well as the 3 transmission sensor connectos. I picked the car up and the CEL came on after 3-4 back road miles.
Any ideas? One problem or two?
