1994 Pathfinder SE V6 Starting Problems
DVD7000
Car: 1994 Nissan Pathfinder SE 4WD
I have experienced the intermittent starting issue for the past several years. Turn the key and everything goes dead. My "solution" has been to keep disconnecting, then reconnecting the negative battery terminal until after 5 - 10 times, it starts. This has ALWAYS worked without doing a single other thing, so make of it what you will.
Last year I noticed a lot of corrosion on the positive battery fused link bundle, so I doused the entire block with baking soda and warm water, then scrubbed lightly with a toothbrush. The cluster is taped together and I'm wondering if I should cut the tape and do a more thorough cleaning of all the connections. A bit worried that I might damage some of them if the corrosion has eaten away at the wiring.
I suspect that there is also a parasitic drain on the battery, as when left sitting for a week or two, the battery has always gone dead. If I disconnect the negative wire, it's fine. I can't find any obvious things like a light left on somewhere. I've read that sometimes the diodes in the alternator go bad, and that might be the cause of the drain. But the vehicle only has about 80k miles on it. Unless the fact that it's 20 years old might also figure into the equation. I've tested the battery with my multimeter, and when fully charged it's reading 12.3v. With the engine running, it's reading 14.4. The battery is only a few years old, and this problem existed even when it was brand new.
