I just bough a 1994 Pathfinder
My first 4wd actuallly , the body is not too bad , lots of rust under the truck , and a small hole in the driver floor , and it did'nt move for a year or two ,that's for the bad point .
I got it for 1000$ with brand new set of winter tire, 4200lbs winch , it has heated leather seat and the LSD , quite a sweet ride for a beater , the best part of it , 48 000 km !!!! yes , brand new !!!
I had a lot of problem at the beggining , seized caliper and pads (original one....fall apart right away ) , poor idle and huge fuel consumption !!(8/10 mpg )
Long story short , changed spark plug , oil , o2 sensor (engine was cominng from time to time code 33 ) , brake pads and probably other stuff i dont remenber now
It's now running nice and smooth !! Still taking a lot of gas though...
My questions are the following , knowing that it's my commuter for now but will be my go away truck , so hard 4x4 trail and heavy loaded with gear :
Is a aftermarket transmission cooler would be a good idea for that truck ?
Is there a cheap and easy way to lift it about 2 inche ?
Has any of you has a trick to reduce the fuel consumption ? (except have a lighter right foot , i need more autonomy ...)
The transmission is revving pretty high before shifting , is it a known problem or normal (3k rpm )?
2014-12-05 by ptn6, on Flickr
