robertoquintana »
https://forums.nicoclub.com/robertoquintana-u52750.html
Wed Dec 27, 2006 9:54 am
This problem started about a year ago. Let me give you some history. A year ago the engine without warning simply jumped to 1400 revs for a few minutes in idle. Only after turning the engine off for some time or running it above 3000 revs for some time did it go back to its 750 revs idle. This happened randomly. Dealer was unable to diagnose or fix (just guessed) as there was no SES light. From then on idle was slighty rough. Otherwise engine ok.Later on idle began to be rough when hot and at last the SES went on. Valve clearance and tune up were diagnosed. Done engine ok but weeks later idle slightly rough with the added problem of bogging at +1000rev.SES light on again check AAV, fuel preasure, oxygen sensors. New AAV, fuel system cleaned thoroughly including injectors, preasure check ok and engine ok for a few weeks. Same problem appears again. No SES light. Latest guesses Mass air flow sensor may be the problem or the TPS. New TPS great improvement but not complete.
