ibreakstuff »
https://forums.nicoclub.com/ibreakstuff-u76627.html
Thu Sep 20, 2007 12:48 pm
I'll do a write up on the wiring in the truck section when I'm not feeling so lazy.
The swap into the truck is not as easy as a 240. You will need to fabricate motor mounts (I use a 1" steel spacer and the rubber block from the truck mounts with a bolt ran through it. I plan on making solid mounts for it in the future.) You can use the 240 (same as SR) mounts, but the front of the motor will point up.
You can use the stock transmission mount with a little modification, but you will have to cut the driveshaft to make it work.
The front of the truck is smaller than a Silvia so you will have to use an electric fan. I used a 2.5" thick Summit radiator and permacool fan. You will probably need to modify the upper water neck to get clearance for the radiator hose.
Power steering is easy, use the SR pump and relocate the reservoir to the drivers side. I modified the high pressure power steering line with a plumbing flare tool, or you can spend $50 and have one made.
