psilogen »
https://forums.nicoclub.com/psilogen-u106218.html
Tue Sep 16, 2008 1:41 pm
I spent way too much money on this pickup, not realizing what kind of shape it was in. First car of my own, etc. Anyways, when I first bought it it would go about a mile and a half before the engine would start cutting out. The problem would show up gradually, dropping by about 1k rpm then going back to power, but the drops would get progressively more frequent until the point where the engine would just die. I brought it into the shop, where they cleaned the throttle body and replaced the air filter. Now it will drive pretty well just long enough for me to get to work, but if I drive 12 miles or so to run an errand and then try to start it, it will start running and then immediately die on the first attempt or two, then it will run alright. about 8 miles after that, it starts cutting out again, with a rough idle, and has a tendency to die at stop lights. A mile or two after that, it will die when driving.
I've looked around, primarily on these forums, and it sounds like a common culprit is the TPS or the MAF sensor. This makes some sense to my untrained mechanical brain, but the problem is that I only have about a month before I need to either drive this sucker 1000 miles across country (moving), or get rid of it. I know that a multimeter is something I should already own, and I plan on rectifying that tomorrow.
Where's the throttle body located? I suspect it's right under the air filter, but I'd like confirmation before I go to the hassle of d/c-ing a bunch of vacuum tubes, etc. Once I find the throttle body, is there a way to narrow down which element is malfunctioning, if indeed the issue is with the throttle? This truck is also a straight-up rustbucket, so it would be nice to know if there's any wires the could conceivably be causing this problem due to corrosion.
If I haven't clarified something that I should have, let me know. I can also take a pic of the engine if someone's willing to throw a big old MSPaint arrow on it to show my car-dumb *** where to find the knowledge I seek.
