I used the following as a guide along with Wes' help:
Here are Heath's tips:
Q451990 wrote:The biggest trick for removing the dash bezel is removing those two large bolts that hold the steering column up. It'll allow it to drop a couple of inches so you don't snag it on the ignition switch.
Heath
Q451990 wrote:I think you do need to remove the steering column surround... easy though, phillips head screws accessable from the bottom. Remove the part on top of the ignition switch (you'll know it when you see it) held in place by one screw to prevent ripping the cluster surround near the ignition switch.
Good luck!
Heath
and here are instructions from Drew:
DrewQ45 wrote:
Yeah, but first you have to remove that little white plastic thingy sitting on top of the ignition which has a small metal arm sticking up. I think it contains a solenoid. You can't clear that without bending the plastic so much as to break it and you'll still cut up the cluster's dash surround's vinyl on the arm. That's unless you drop the steering column in which case, I'm still not sure you can clear it easily. Jesda, I honestly can't see this being done in 30 mins much less 20 mins. You have to basically pull up everything for that damn clock and I've done it a few times.
..Drew...
