1994 Nissan Pathfinder- Wheel Bearing Help
Techniker
All,
I work as a mechanic, but I don't come across Nissans that often. I have a customer coming in with a 1994 (first generation) Nissan pathfinder 4WD that requires wheel bearing repacking.
Does anyone know what spindle nut socket works on a 1994 Nissan pathfinder?
Most other techs resort to the punch-and-hammer method when they come across a lock nut that they don't have a specific socket for, but I would rather it not come to that (good luck torquing with that method, for example).
Thank you in advance,
Techniker
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
I was about to suggest posting on NPORA since not many of us here own WD21s (most of us here have 1996-2004 R50 Pathfinders), but I see you have already have :)
Sorry that I'm of no help otherwise, but welcome to NICO!
One thing you should probably tell to your customer: if the vehicle has an automatic transmission, the stock cooler is prone to clogging; as a result, many WD21 owners bypass the stock cooler and install an auxiliary transmission cooler. If the vehicle has a manual transmission, there is a TSB for 4WD 1986.5-1995 Pathfinders stating that the transmission must be overfilled; read here.
Ron Burgundy
Car: 1999.5 Nissan Pathfinder 3.3 LE
