loystock »
https://forums.nicoclub.com/loystock-u10145.html
Thu Apr 08, 2010 9:42 pm
If there is no record of flush in the last 80K miles, most shops will not even do it due to liability issue. You might as well do a series of drain and refill - 3 to 4 times to get most of the fluid replaced. Ensure the engine is warm and the transmission fluid is at the correct level before doing drain and refill. Then run the engine for @ 100 seconds while changing gears (must apply brake), stop engine and drain immediately. Add ATF to match the amount drained. Repeat 2-3 times.
It would be better if you could do a pan drop, clean the pan and magnets, inspect the filter and replace as required. Transmission service kit can be bought from IoS-infinitiparts USA.com.
Preferred fluid is Nissan Matic-D but Dexron III or the latest Dexron VI should do the job. You need a minimum of 12 quarts for multiple drain and refill, more if you drop the pan. Add a bottle of LubeGard Red ATF Protecttant (@ $14 from Napa) after transmission service.
For optimum brake performance, brake fluid should be flushed every 2 years. A good fluid has champagne color. Brake fluid is hygroscopic so water tends to get absorbed over time which could compromise braking efficiency.
A worn out belt must be replaced immediately. Struts are typically replaced every 60-90K miles.
As for the fuel service, you can buy a bottle or two of Redline SI-1 Fuel System Cleaner (@ $8 from Napa) or BG44K (@ $18 on line). Add a bottle for each full tank of gas.
