1994 Nissan 240sx
Garland62
Car: 1994 Nissan 240sx
Newbie here
I need help with my 1994 Nissan 240sx
Problem is when you start driving the car is operates normal but after an 1/2hr or so it just seems to loose all power. For example if you stop for any reason and then go to start out there's little or no power, if you keep the rpm's between 3000-4000 and it will slowly start to move. Can anyone tell me what me be whats wrong or what to check?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Clogged exhaust or fuel system....Cat or fuel filter maybe.
OriginalWheelman
Car: '15 Ford Focus Electric
Is it an automatic? It sounds like the transmission is overheating.
PapaSmurf2k3
Site Admin
Yeah sounds like the trans might be the culprit. If you put it in neutral, the engine revs fine and everything?
Garland62
PapaSmurf and Wheelman
I put a new clutch in and replaced the transmission fluid also replaced gear oil. Is there something else I should check or that I've over looked?
Garland62
Infinitiguy
Any suggestions where to start checking? I'm not that great with cars.
PapaSmurf2k3
Site Admin
Is it an automatic, or did you swap a manual into it?
I'm guessing you swapped a manual trans in, seeing as how you mentioned the clutch.
