1994 Mxima sohc timing belt
012siuol
Car: 1994 Maxima
I have a 1994 Maxima i'm trying to replace the timing belt. I have the timing at TDC put belt on the three lines are on the marks both camshafts and the crankshaft turn the crankshaft twice the camshafts and the crankshaft are still at TDC, but the belt lines are not on the marks. HELP!
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
MoD, you got any info here?
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
Don't worry, when you put the belt on and the marks line up you've got it in time. You have to turn the crank a certain number of times before they line up again so no worries.
012siuol
Car: 1994 Maxima
thanks so much. 1? what if one camshshaft and the crankshaft lines up and the other camshaft is three to four teeth off?
mtcookson
1992 Iinfiniti Q45
and much much more
As far as the marks on the belt or the dimples on the cover? If its the belt then its no problem as those marks on the belt should only be referenced when putting the belt on. Once you start spinning it, the marks on the belt have no bearing on the timing.
If you want to make sure that it is in time just spin it and check to see if the dimples line up (they won't be exact but will be in the vicinity).
