012siuol »
https://forums.nicoclub.com/012siuol-u33841.html
Wed Nov 19, 2008 8:28 am
My 1994 Max just won't start. I let someone use my Max for they had no transportation it was missing when they got it . They had somebody work on it and it hasn't really started sence. I've gotten it back crank it it started real rough at a low RPM and black smoke for about two minutes and quit. I got it home replaced the timingbelt, two injectors, coil, distributor, wires and plugs. It still won't start. I pulled the plugs they were soaked with gas. No spark right? I use OHM meter to check coil, it checks ok checked power transistor could not get a reading. Went to junkyard checked about twenty power transistors and niether one gave a reading. Can someone help?
