1994 J30t Tension Rod Bushing... Help!
halfbyte
Greetings all;
I have 94 J30t with 91K miles. I noticed grease leak both left and right of the front. And after a quick look at it... it's my tension rod bushings all shot and leaking...
Where can I buy them and how can it be replaced? Is it simple as undo the bolt, replace bushing, and bolt back on? Let me know.
Thanks in advance.
driverdriver
Car: NICO's longtime resident Canuck!!!
Used rods can be bought at an auto recycler. If your looking new try a dealer or one of these boards sponsors. Its a part that is dealer only.
DAEDALUS
Car: 1990 Infiniti Q45
One of our sponsors is a wholesale parts manager at a dealership in Scottsdale, AZ. Call Joe at 1-888-216-5328. The bushings for the Q are around $15, I'd guess for the J would be about the same. Easy fix to get the rod in and out, not sure about the bushing itself.
halfbyte
I've ordered tension rods both left and right throught Joe @Scottsdale.
Thanks all.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
halfbyte wrote:I've ordered tension rods both left and right throught Joe @Scottsdale.
Thanks all.
Did you get just bushings, or the entire tension rods?
halfbyte
I've got the entire tension rods. (Both left and right). Job took about 35 mins both and J30t is back in business.
Thanks all.
pulsedriver111
Car: 1994 Ifinity J30 3.0
i really need help with my tension rod bushings for my 94 j30, but im from belize city, central america, how can i get them here, credit card?? does anyone has a part # i can try to hunt in the net for, please help, so desperate for those bushings.
thanks,Giovannie
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
You may want to Check the bushing diameter if you are not the original owner before ordering
I purchased 2 Original Nissan bushings to put into my newly acquired 1997 J30 part # Nissan 54476-35F20
After pressing out the 2 old ones I found the new ones were to small.The ones that came out measured 69.5mm OD the new ones and the ones in my 1995 J30t are 64mm OD. per every were I look they should both be the smaller ones. I then purchased rods from some one parting out several J30s and 2 of the 3 rods he took off of J30s were 69.5 MM ones
After extensive hunting the 69.5mm is a Q45 with active suspension64MM is all J30s59.2mm Q45 non active
There are instructions on replacing the bushings here http://www.fuzzycats.com/j30_diy.htm under Tie rods
Thanks
Q45tech
There were different diameters for Q45, Q45t, Q45a, J30, and other Nissan models plus there were specials to correct caster problems [imbalance-drifting].
Most one just sees a few variations today since the entire assembly [metal arm and bushing] are replaced as one unit.
Important that the length from center of bushing back to mount bolts are equal side to side or the caster will be different.
Sometimes special mix and match were used by dealers/alignment experts to fix frames where caster was not matched after accident.
Cheaper to tweek a $100 part than rebend the front frame after a core support replacement.
Used cars are used and often very abused!
